OVERKILL
$100 Site Donor 2021
So, started using the rear-heat in the Expedition and then all of a sudden the vents were cold when I was idling... uh oh.
Now, I flushed the coolant in the summer with Zerex G-05 and I flushed, then burped the rear heat lines then.
However, when I had the plug blow-out fixed at Ford, they disconnected the rear heat lines, as there was coolant on the invoice and the plug (#4) has the rear heat lines running right over top of it.
The coolant level had been fine since then, when looked at through the reservoir.
So, I pull into the Brafasco parking lot, and their appears to be low coolant in the reservoir. I have a 4L jug in the back, no big deal I think......
I open the top.... "PSSSSSSSSSSSSSSHHHHHHHHHHHHHHHHHHH" the pressure releases, and the coolant that was there, disappears down the hole. I start dumping coolant in... and dumping, and dumping.... there goes the whole container. There's still none in the reservoir, uh oh!
I go to Canadian Tire, grab a 4L jug of straight coolant and go home to mix it with distilled. I now have heat at idle BTW, so here's our problem!
I mix up 1 jug, go out and dump it in, we are now just above the hole in the bottom of the reservoir, WOW!
Back in the house, grab the other jug and end up putting about 1/2 of it in to bring it up to the full-hot mark.
This was yesterday. The level hasn't moved and I've put about 100Km on it, and it is holding pressure.
So I was down 8.5L of coolant!!!
I can only assume that when Ford removed the lines, they didn't burp the rear heat and just topped the reservoir back up when they started it.
