Hi everyone,
I have a 2001 Mitsubishi Mirage 2dr that I use on a technical but smooth circuit.
I run 205/50/15 semi slick tires on it and the front is exhibiting odd wear pattern.
The tires are getting very little wear on the outside with most of the wear being in the middle.
I know this suggests that they are over inflated (I run 32psi hot) however if I start dropping the pressure from 32psi hot grip seems to suffer.
I am running -2.5 camber and +6 castor at the front with 1mm total toe out (-1.3 camber rear, 2mm toe out).
Springs are fairly stiff but there is enough roll (9kg/mm all round).
At the same time my front end grip is very limited with lots of understeer which I assume is due to not using all of the tire contact patch but I have no idea what to do.
I will be going softer front swaybar.
Is it possible that I am running too much camber/castor?
