Evening all. So I posted earlier about a weird fuel gauge issue, but it seems like there is more to it. I can't put my finger on what is going on, but I'm thinking either a weak/bad battery at best or bad PCM at worst. Most of the issues are seen when starting the car. It started with what I thought were two unique issues - traction control being disabled at startup and a weird fuel gauge at startup. But given the additional stuff, I'm thinking these could all be related.
Symptoms:
Symptoms:
- Sometimes the fuel gauge shows empty at startup even though there is fuel. 0 miles to empty will be displayed on the screen, fuel light will come on. Needle will slowly crawl up to correct level in anywhere from several seconds to a few minutes
- Sometimes the traction control will be disabled upon startup. It can be turned on via button and will stay enabled the whole drive.
- Now seen regularly at startup, the temperature gauge swings to full hot for a couple of seconds and the display warns of an over-temp before swinging back to cold. This happens on a cold start so there is no heat at all.
- Sometimes also see that hill start assist is disabled
- When I scan for codes, I get a P064F which is permanent? "Unauthorized Software/Calibration Detected". No changes have ever been made to the PCM.
- The vehicle is a 2019 Ford Transit Connect with the 2.0L gas engine and has about 53K on the clock. No tunes, mods, or hacks.
- The car otherwise fires up and drives normally
- Disconnected the battery for over a half hour to try to reset the PCM to see if that would help, but no improvement
- Cleaned the wheel speed sensors and tested that data is accurate with Forscan and a short drive
- Run several cleaners through the tank thinking a sticky sending unit, but not so sure anymore given the context of the other issues
- I believe the factory battery is an AGM (based on research). The car is getting on seven years old. I haven't tested it yet, but it starts fine and hasn't overtly exhibited an issue. I was going to try putting a charger on it for a while to see if when I start it, I see the same behavior. I may throw my tester on there but I don't know how much I trust mine and the battery is awkward to get to. I have been tempted just to replace it since it may be close to expiration based on time.
