hi guys,
so i've got a 96' BMW 318 automatic. its a 4-spd auto transmission... i think its a GM.
anyways, the car shifts perfectly normal in the summer. only problem i have in the winter: when i first start the car in the morning and start driving, it holds on to the gear for alot longer than it should. like, instead of changing gears when i let off the gas a bit, it keeps in gear and i pretty much have to push it to about 4000 or 4500 RPM to get it to shift. its weird, because its only in the morning when its cold, but it only happens for the first 2 or 3 shifts, then it stops... so its not like the transmission fluid is already warmed up. no way. i dont know... i just don't get it. i know its not slipping. the shifts feel fine when they happen. its just the first few shifts i have to push it so hard to get it to go.
why is this?
i haven't changed the transmission fluid since i got the car 2 years ago, and i have absolutely no service records from the previous owner. i picked the car up at 160,000 KM and now its at 190,000 KM.
could this be the reason? could it be in need of fresh ATF?
why is this?
