Weird PC problems
southeast US
This is a perplexing problem and I'm trying to figure out if power supply could be an issue.
The PC is an ancient P4 dell with XP used by my wife mainly for word processing, email, and Picassa. My wife is attached to this and doesn't want to transition to a newer hardware with a "newfangled" windows 7 (I know!).
The PC was supper reliable up to now, and I used to play BF on it when it was new.
Couple of days ago it froze when my wife used MS Word and she lost 2 hrs worth of editing of a paper.
Yesterday, I did AV and spybot scans that revealed no infections. PC worked fine, but I noticed DVD-RW drive not showing up. I did the MS registry fix for that and restarted.
Well, no mouse or keyboard would worked after restarting that prevented me to log in in windows, even under safemode.
I tied a different mouse and nothing.
I thought I screwed up the registry edit somehow and restored the drive to the most recent image via Ghost.
I restarted, mouse didn't work, but keyboard did and I logged in Windows, but some missing windows disk error showed up and PC froze.
I restarted again and tried a new mouse again.
The new mouse was red LED optical rather than IR and I noticed that there was no light, thus USB port was malfunctioning. Another USB port worked and than stopped shortly.
Then I thought about RAM and ran a MemTest and it passed.
I restarted and plugged in an old non-USB mouse and it worked. Later, USB mouse worked too, even in the "bad" USB port.
Now the PC works with no issues. I never had such weird failures. Is this a sign of PS going south? How do you test those? What else? BTW, the caps look good on the MB.
DL HWinfo32. Not sure what all sensors it will support in that rig, but it should give you bus voltages. If any are out of spec or fluctuate, it's probably your PSU.
Find who the manufacturer of the hard drive is, then download the diagnostic DOS disk from them, then run tests on that hard drive, this will either tell or eliminate a hard drive problem.
Thanks all for the feedback, wifey is using the PC almost non-stop now, so I can't do any further diagnostics. Sounds like it's working fine again. All data was backed up yesterday.
HWinfo32 is a free download that will give you date immediately. There really isn't any reason she can't go to http://www.hwinfo.com/ while she's working, download the 32 bit version and load the program when it finishes loading.
Load up your machine and see what voltages do.
Thanks for the tip. I finally pried my wife from the PC (she is very busy at her online courses) and installed the HWinfo32.
Sadly, Dell didn't bother to put any voltage or temp sensors on the motherboard.
I will have to use my multimeter instead.
The PC worked fine since without any glitches (almost non-stop, my wife shots it down overnights).
BTW, I did multiple drive checks and no bad sectors or errors showed up. SMART data is good and the drive has under 3000 hrs.
