weird noise from brake pedal 05 f-150
millington tn.
My work truck is a 05 F-150 and today I noticed an odd noise coming from the steering column.When I press the brake pedal down I can hear a light clicking sound that I think is coming from the stearing column.Maybe a Ford mechanic has come across this problem .
snowblind in TX
Sounds like your "Park" interlock solenoid on the column. They all make a click sound to some extent when the brake pedal is pressed.
Chicago Area
If the noise is a change from previous noise, then check it out. With the car off, try depressing the pedal on/off while you crawl under the dash and inspect things.
