I have almost 3 year old JC battery in RAV4 that I considered dying because voltage would drop to as low as 12.2V after sitting unused for a couple of days. Mind you, I checked for abnormal parasitic drain and there is none.
Today, I decided to put some load on it and turned ignition and lights on without starting the engine. The voltage under load went down to 11.74V and stabilized there, the lights were bright and everything worked fine. After a few minutes, I turned it off and voltage slowly returned to 12.4V, higher than before the test!
I couldn't believe it and repeated the load cycle again. Again, the voltage recovered to even higher 12.43V.
The battery tests weak for its size (10.3V) on my small, 50A load tester.
What would cause voltage to go down with sitting and improve with load?
Thanks!
Thanks!
