Originally Posted By: mechtech2
Tegger - Yes but....
Temperature [ambient] is important to battery V readings. This must be addressed.
You're right.
Bill Darden has a table up on his site that tells exactly what the voltage should be at each 10-degree increment in ambient temperature.
See here:
http://batteryfaq.org/
and download the Excel spreadsheet by clicking the link that says, "Temperature Compensated Battery State-of-Charge (SoC) Table".
And to do that running test, it should NOT be at idle - rev it to 1,500-2,000 RPM.
A good alternator/regulator should be able to supply at /least/ 13.5V at idle with the engine hot. When cold it may supply as much as 14.6V. That's with the ELD allowing full-charge, of course.
This Honda has an ELD. With the engine hot, the ELD is likely to hold voltage down to close to 12.65V, confounding troubleshooting efforts. I can't remember exactly what to do to force the ELD to allow full-charging on a warm engine, so it's easier to check the charging on an ELD-equipped Honda using the method I gave.
You're right.
See here:
