I've been smelling antifreeze in the engine bay whenever it's cold. Someone told me that there is a weep hole in the water pump that leaks out coolant when the pump is about to go bad. Is it true? The manual says to change the water pump and timing belt at 90K. I have 68K on the truck. Plus it's driven by the timing belt.
Also I'm running a higher ratio of water to antifreeze (12 qt system - 4qt coolant/8qt water.) Could that also cause weep hole leakage?
