I have a chery A5 car, its model has only fresh air filter, no filter for circulation a/c.
I was running a/c with low and fan speed at 2 or 3 Max. I'm in Egypt so temp. Reaches 40+ easily in summer.
A few months ago a/c went weak in air flow not cooling temp. Means that front seats passengers will feel ok with fan on 4+ while back seat passengers feel hot even with the back air vents located in middle console.
freon Ratio is fixed and I've changed freon machines many times by changing places, also I've cleaned the evaporator and external fresh air filter, even changing it also I've cleaned the blower, all of that without positive results.
Do I have to change the blower or you may recommed another solution?
