We Shall Never Surrender! 2012 Sonic Outer Tie-Rod End
Winnipeg MB CA
This is my friends' 2012 Chevy Sonic. It started clunking/knocking badly on our rough roads, and the owner thought it might be a stabilizer-bar end link. (Reasonable assumption - this car has eaten any number of end links, but has been good since @14Accent recommended the greaseable Moogs. But it was a possibility.)
But anyway, I started investigating and right away found a very sloppy outer tie-rod end on the driver's side.
My friend picked up the parts locally, and I figured it would be an easy repair.
The darn thing fought me every step of the way.
The ball-and-socket assembly was so worn that I couldn't remove the nut on the end of the spindle. The nut and shaft spun together. There was not enough exposed thread to hold onto with grips while turning the nut. I had to cut it off with the grinder. (True confessions - it was easier to cut through the spindle above the knuckle. I couldn't figure out why the spindle wouldn't drop out, and eventually realized it was a tapered fit. Duh! Had to cut off the nut and spindle on the bottom side, and drive it out the top.)
Then the lock nut was seized in place. I was finally able to back it off a few turns with much effort.
And finally, there was no way the outer tie-rod end would come off the threaded inner easily. I tried penetrating oil and my inductive heater. No way.
There's no flat on the inner tie-rod for a wrench, so I had to use a pipe wrench to hold it.
Finally I resorted to the grinder. I cut several parallel slots in the body of the outer tie-rod ends, terrified each time that I would damage the threads of the inner tie rod, and squirted in penetrating oil.
It still fought me, screeching with each small fraction of a turn.
The threads of the inner tie rod were covered with some sort of dry gluey substance. I got a die (14M x 1.5) on it, and cleaned up the threads.
Needless to say, the new locknut and outer tie-rod ends went back on with lots of anti-seize.
With a bit of trial-and-error, I set the toe to zero using Tenhulzen alignment plates - the front and back readings were both something like 65-15/32").
I checked the toe before we started, and it was at 0°. Given how the inner and outer tie rod sections were pretty much fused together, I doubt the wheels had ever been aligned. Hats off to Daewoo for making a front end that that stayed aligned for 14 years.
We went for a drive and the car tracked OK and didn't make any front-end noise. Phew!
I did not expect this at all, but my friends gave me a very nice gift (a Kobo e-reader).
Here's the carnage:
This is one of those things that has very little labor, is much easier on a lift and requires an acetylene torch. I would just have gone to a shop! But good for you on helping a friend out. (y)
I was thinking that it would have been much easier if it were up on a hoist. I've done a bunch of these - this was by far the hardest.
I did the other (passenger) side this evening. Everything came apart easily.
Why was the other side such a beast?
Unsolved mysteries ...
Did someone before you potentially use thread locker on it?
The owners bought it new, but I have to wonder ...
They had a set of stabilizer-bar end links replaced at Midas a few years ago, and the ball joints replaced at Canadian Tire, so others have definitely worked on the front end in the past.
They are pretty sure that these outer tie-rod ends were original though. It's a bit of a mystery.
