I was replacing my inner and outer tie rod. Inner did not have any play in it but would flop down and it was obvious it was on its last legs.
I was wondering. How often do you replace the inner and outer tie rod together? Just the outer? How many outer tie rods does the inner last?
Because I live in the rust belt I was able to "decipher" the rust rings around the inner and outer to determine that they were both the same age.
What are your experiences? I guess it differs depending on the vehicle? O heard that dodge trucks have front ends that need constant work.
Also I only replaced the one side, the other had zero play and was tight.
