The fact is that he wouldn't have sprayed it directly into the filler hole, so all you would have got was an over-spray mist that wouldn't amount to more than a few drops of actual liquid.
It won't have any significant effect on your oil. And in any case it will vaporize and be drawn off though the crankcase ventilation system the first time the engine is hot.
Remember that your oil is always being "naturally" contaminated by gasoline, water and acids from the blow-by process every time you drive it. You don't have to get too precious about it.
