I have to refill the fan clutch on my W124. Fome some reason, the special tools aren't available anywhere. Basically a flat 36mm wrench and another one to hold the water pump. What would you suggest? A standard 36mm wrench is too thick to reach the nut. I've seen people doing this with a screwdriver and a hammer... Otherwise, building the tool from a steel sheet would be possible too. I'm all hears!
