No worse than the sun beating down on them.For normal upkeep, it seems general waxing of (plastic) lens is good in a similar way to the paint.
My question is to what extent does the heat from the bulb can have undesirable affects on the wax finish?
A testament to Nissan's quality more than the effectiveness of wax.I've been waxing the headlight lenses(after every wash & more) on the 2015 Altima in my signature since I bought the car in '15 and they're still starting to fog slightly.
Normal ageing from sand blasting by road debris and UV exposure. Anything you can do to mitigate either will extend the life of exterior plastics.Yes good point I know hot sun (+UV)accerletates the fogging. Unfortunately when it comes to sun, we have been seriously short changed here in the uk!
Is this the normal ageing process or you think waxing has a part to play?
Or, depending on the chemistry used for cleaning, you'll burn through the UV coating on the headlight faster.My 2002 vehicle has crystal clear lens, but I'm retired and park in a garage.
I also think regularly using a Cleaning Wax would help.
I never thought about that..(the cleaner wax possibly burning through the UV coating)..I've waxed my headlights for years with whatever wax I had on hand...I'll be more selective in the future. Do you recommend any in particular? BTW...What does PPF stand for? Thanks.Or, depending on the chemistry used for cleaning, you'll burn through the UV coating on the headlight faster.
