Wax on black rubber/plastic moldings
Indiana
I just bought a very nice '89 Porsche 3.2 Coupe. There is some white staining from wax on the black surround molding on the whale tail as well as some of the door weather stripping.
What is the correct/best way to remove/cover this?
Thanks,
David
I second the peanut butter recommendation. Although I haven't tried it myself, I had a wax manufacturer (Collinite) tell me that peanut butter worked well for removing the white stains from black plastic trim.
To keep this from happening again, you can use wax that won't leave a chalk residue on trim such as Zymol and P21S. If you don't want to do that, apply trim protectant prior to waxing and then after waxing.
Big Dave,
I am a P21S fan, too.
If you're ever intersted in trying something new that will never stain trim do an internet search for Optimum Car Wax Spray.
It is truly wipe on/wipe off. Excellent results on my wife's black Highlander...
White vinegar...does everything you need without the peanut mess
Keep car windows frost-free overnight in winter by coating them with a solution of 3 parts white distilled vinegar to 1 part water.
Polish car chrome with full-strength white distilled vinegar on a soft cloth.
Remove unwanted decals and bumper stickers by covering them with a cloth soaked in white distilled vinegar, or by repeatedly spraying them with full-strength white distilled vinegar. They should peel off in a couple of hours.
Rid the windshield wipers of road grime by wiping them with a white distilled vinegar-soaked cloth.
Remove the leftover odor after a rider has been carsick by leaving a bowl of white distilled vinegar overnight on the floor.
Get rid of hard water stains on your car with a rinse made from 3 parts soft water to one part white distilled vinegar.
Wipe vinyl upholstery with a mixture of equal parts white distilled vinegar and water.
Remove winter road salt residue on car carpeting by spraying with a mixture of equal parts white distilled vinegar and water, then blot with a soft towel.
Remove the hazy film that builds up on inside windows by spraying with white distilled vinegar.
Remove dirt and stains from car carpeting with a mixture of half white distilled vinegar and half water.
When doing car maintenance, soak rusty bolts and screws with white distilled vinegar to make them easier to remove.
Loosen chewing gum stuck to carpeting or upholstery by soaking it in white distilled vinegar.
Create an all-purpose window cleaner with a few ounces of white distilled vinegar in a quart of water.
Give leather upholstery an extra shine by cleaning it with hot white distilled vinegar and rinsing with soapy water.
Make your car extra shiny by adding a few drops of white distilled vinegar to your bucket of water.
