Waterproof Grease --Aluminum or Calcium Complex
Look at the water washout rating. Usually ASTM D-1264: "Water Washout @ 79°C (175°F), loss, weight %"
Here are the rating for some of the greases mentioned from their Technical Data Sheets:
  • Bel-ray waterproof grease: 4.2 %
  • Lucas marine: 2.75 %
  • Lucas X-tra heavy duty: 10.0%
Also look at copper strip corrosion test (ASTM D4048), and useful temperature range - might have an impact for your brake application. Most marine grease sacrifices high-heat stability in favour of corrosion inhibition and water washout properties.
Originally Posted by berlyn
^^ great info here, thank you. If only the access to their TDS's was easier.. At least in EU.
It sounds almost like Buzzy's Slick Honey, which is what pushbike mechanics use on the pivot points of full-suspension mountain bikes as well as suspension forks and rear shocks.
Here's the US TDS for that Bel-Ray stuff: http://www.belray.com/wp-content/uploads/2019/02/Waterproof-Grease.pdf
No, nobody is using it in pivots, waterproof grease goes there
It's a seal grease
Same as slickoleum.
Yep, I have some of that green Bel-Ray Waterproof Grease in my garage. That's what most dirt bike guys use.
Bel ray is not an ep grease,
A better aluminum complex grease for linkage pivots and the steering stem bearings would be schaffers 274, contains ep additives (mos2)
Don't use either for the wheel bearings.
