Although it may succesfully be used in other applications, I think Redline Water Wetter was originally intended for use in racing applications with water only. I believe that is why it has it's own corrosion inhibitor that seems to be at some conflict with some coolants. From all that I have read in the past it is not a wise habit to reduce automotive coolant concentrations below 35 to 40 percent in most(if not all)modern vehicles while following the recommended maintenance schedule. If you were to increase the flushing/coolant change frequency(change/flush more often) you might possibly be able to reduce the concentraton, but in the way most vehicles are used (daily drivers, extended maintenance intervals, expected durability, racing excluded)I am inclined to defer to the engineers recommendations and follow the owners manual. I will continue to use a 50% coolant for my region.
