Guys I need some help please. After driving home 26 miles one way tonight, I noticed me engine had an odd sound. It just didn't sound exactly right and had a very slight vibration as it idled in the yard here at my house. This is in my 01 Dodge Dakota, it has a V6 engine and 141,150 miles on it. It still has its original water pump. I checked and the upper radiator hose is hot like it should be. The lower radiator hose is cold. Both heater hoses are hot, one seems to be slightly cooler than the other. My truck never overheated or had any problems coming home tonight and the heat works great. I had to turn it down to about half way on the temperature selector and put the fan on low. The heater has always worked very well like that.
Does this sound like a bad water pump to you, or something else? I have had the coolant flushed 3 times now since I bought the truck 102,000 miles ago. The radiator is new, thanks to being in a front-end wreck back in March last year. Before that, the radiator was replaced in 2007 after I hit a small deer. The thermostat is about 3 or 4 years old now, it's a Napa Super Stat, I would think it would still be OK.
I am guessing water pump here, but like I said the truck did not and has not ever overheated. I looked at the bottom of the water pump, there is no coolant dripping out of the weep hole, but there is a LOT of dirt and crud on the one side of the bottom of the pump, the other side is relatively clean. It's hard to get a good look at the entire bottom side of the pump, but I am guessing the weep hole has been leaking and instead of dripping to the ground, it mixed with dirt and grease/oil on that side of the engine instead.
Any help or ideas on this is very much appreciated. Thanks.
