Unfortunately my new shop is about 200 yards from the water meter and most of that is 1/2" plumbing. I get almost 80 PSI pressure from the hose bib, but when turned on full blast I only get about 150 gallons/hour. That is pathetic. I can pee faster than that. My hose at home is around 800gal/hour. I can't even hook my pressure washer up to that at the shop. (3GPM)
I can get a clean, food grade 330 gallon "tote tank" for pretty cheap, and hook it up with a float valve so it fills itself like a toilet. Then, with an electric pump, I can draw much more than 150GPH. Kind of like an air reservoir.
My question is what kind of pump do I need? I'll basically consider my tank to be a "shallow well". Will a pump like this work?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=2955
I've never had a well before, so I'm not quite sure what the 5 gallon tank does? Would this provide me a continuous 800+ GPH out of my hose?
Then there's this pump, but I think it's designed to work with input pressure, not gravity feed. Am I wrong? It's on sale for only $99 at the local store. Maybe I wouldn't need the tank with this kind of pump?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=96719
Then again I could go gas powered, I wonder how many PSI this thing can put out?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=66585
