Originally Posted By: grampi
Originally Posted By: rslifkin
Idle warmups wash a bit of excess fuel down the cylinder walls causing some extra wear.
Prove it.
Unfortunately, I don't have a good way to do so. However, when the engine spends more time at low rpm under no load (low combustion temps), and it's in cold start enrichment (extra fuel being dumped into the cylinders), there will be some fuel washdown on the cylinder walls, which causes extra wear. Mind you, this wear is probably insignificant and not going to shorten the life of the engine in any meaningful way, but it's there.
Prove it.
