I've got the fuel rail off our 1999 454 Suburban while I'm changing the intake gaskets. The truck has trouble starting when it's warm. Have it warmed up, turn the engine off, wait 15 minutes and try to start it again, it's gotta crank way longer than normal (probably ~5 seconds) before it fires. Driveability is fine, no fueling problems while idling or running AFAICT.
From my reading, this is generally caused by either the fuel pressure regulator or the injectors. I was guessing the FPR, both because it's the first thing I read about, and also because the problem isn't really that bad and the injectors are more expensive and more of a PITA to replace I would think (this vehicle is not a daily driver).
Is there anything I can do to test either the injectors or the FPR while the rail is off the car? If not, I'm tempted just to replace the FPR even though it feels a little like shotgunning the problem. I'm sure not going to replace the injectors without good reason though.
Anything I can just inspect even? If I open up the FPR, will any malfunction be obvious or do the diaphragms just "stretch out" or something that might not be noticeable on inspection?
