Walnut Blaster for GDI Intake Valve Cleaning
CA
I finally need to buy a walnut blaster for intake valve cleaning on GDI engines. A relative’s Audi 2.0t could benefit from a cleaning (due to mileage) so this may be the final motivating factor.
It seems like there are only two options on the market: the Harbor Freight options (and various iterations of it) or the BMW factory service tool.
BMW one: https://www.ecstuning.com/b-genuine...pNMvy2PbOmslHWbAPoFQnJKF30B569JYaApXLEALw_wcB
Ideally I would like to spend around $500 for a mid-priced option plus adapters as-needed, not $1k+. But I am not seeing any other options. Is anyone aware of any other units I should consider?
Are you really going to get enough use out of a niche item like this to justify? I get the need for walnut blasting, but I wouldn’t be keen on having it done. What does it cost to do a service like that at a dealer?
Subscribed. Interested to understand if purchase of a tool like this is worth it…
Found mine.
Thanks for the feedback. I was advised that the HF unit has an issue with clogging and it wasn't pleasurable to use. I am splitting the cost of the unit with a few people, so I am not entirely opposed to spending more if it improves the user experience.
However, I came across this video where zip-ties (in a drill) was used to clean the intake valves. If you compare the photo at 2:33 versus the original photo at 0:37, the improvement from scraping and using the zip-ties (in a drill) is pretty darn impressive. Most of the carbon was cleaned away. Perhaps a walnut blast may not be necessary?
IVD accumulation is not a linear process, given that they attach better to other deposits than they do the valves. The valves look OK at 2:33, but there are enough deposits to which new deposits can adhere that I'd say there's a substantive difference between 2:33 and after blasting. When you consider that most of the work is in removing the IM, I'd say to blast them.
I've done it twice, both times on VAG products. I used a home-brew set up similar to the video above, but used tape around the shop vac attachment and also put a rubber grommet on the hole I drilled, to keep it as clean as possible. It worked perfectly for me.
thats why i dont own any DI engines + being 73 YO with 2 lo mile vehicles + driving less than ever i prolly will NOT buy a vehicle unless someone on a cell phone hits + totals mine!!
Nice looking machine . . . I do have two vehicles with DI engine . . .
Every Euro tech I talked to said it was easily worth 6x the cost of the HF setup.
Dealer charges well over $1k for a walnut blast so buying this tool was still cheaper than sending the job to the dealer.
The HF setup is a simple siphon unit and okay for occasional use. The unit you got is much better if you are going to do enough work to make it worthwhile. I do a lot less work that I used to so for me it does not make much sense, in my case it would sadly be just another nice tool for my wife to peddle on craigslist for 10c on the dollar when I am gone. LOL
Except you have to store that monster someplace!
