Walmart Multi Complex Red Grease OK for Ball Joints?
TX
As the title says, I just replaced my original Motorcraft (non serviceable) ball joints with Moog's. The new ones have zerk fittings that allow for grease. I have a brand new tube of ST MC grease sitting there and wanted to know if this is a decent grease for this type of application.
That pretty much is the default grease used for chassis components like ball joints. There's sure to be better greases out there, but just about any #2 multi-purpose grease should suffice!
It's GC-LB rated, so yes it's rated to use in wheel bearings(GC) and LB(chassis).
Some manufacturers recommend using moly fortified for chassis components.
I use it for everything. Tractors , mowers cars /trucks...should be fine
I just learned about this certification. This is a whole new world to me since I haven't had to grease ANYTHING since 2007 lol I just used whatever the shop had in the guns when I was working as a tech.
