Walmart has Castrol brake fluid on walmart.com
USA
Castrol brake fluid has been hard to find recently, but now you can get it from Walmart at a fair price
The 32 oz bottle is $10.32
The 12 oz bottle is $4.06
Free shipping to the store
If you want it shipped directly to you, you need to order at least $35 for free shipping, otherwise $5.99 shipping charge per order under $35
Exactly, that's expensive for DOT 4 too.
Thou, I run Ravenol J3A1001 DOT 5.1 in both cars now, got it from Amazon when price was low.
Will switch to Bosch ESI6-32N during next brake fluid flush.
Originally Posted by Lubener
What's so exciting about Castrol brake fluid??
Their formula is supposed to absorb moisture more slowly than the others
Originally Posted by A_User55555
How much better is it than the supertech or prestone brand?
It has a lower viscosity and higher wet boiling point. Dot 4 minimum is 311. Castrol's is 329
Both Ravenol and Bosch I mentioned above are LV fluids with 359 deg and 365 deg wet BP respectively.
I'm not sure there is point of buying or using DOT 4 anymore, imho - either very cheap DOT 3 if it can be used in the car or DOT 5.1 for better specs.
