Wagner rotors
BREMBO. I have Brembo rotors on the front with Akebono Proact pads on my CR-V and the performance, low pad wear, and lack of any warping despite my driving has been phenomenal. Powerstop rotors warped and started to vibrate on me last go around. I still have the PS rotors on the rear with the Akebono pads. I have 30K miles on the Akebono pads and they are at half life or better.
I wonder how many brake jobs, all 4 pads on an axle wore out evenly to the point of needing new pads? What I see is something goes wrong and one pad wears down to nothing requiring a brake job on the axle.
I see the Wagner E-coated are back on Amazon for my F250. I order two for the rear. I bought the same ones in 2018. Free shipping on Amazon is a big plus for a heavy item like rotors.
Yes sir that's the deal breaker with rock auto.
I use RA because even with shipping they beat the brick and mortal prices. And it comes to the house. My only local option is NAPA and other stores are an hour away.
I've used Wagner in the past, coated rotors, with no issues. OEX pads also.
I'm not sure what you thought I wrote, but I will say that if one pad wears faster than the other, it usually comes down to the slide pins sticking. 90% of what people think is a seized caliper is actually stuck slide pins.
I agree most uneven brake pad wear is the caliper not floating properly. But my front brakes of F250 had one pad wear to nothing and fall out of caliper bracket. The pin was not stuck or seized but was partially dry of lubricant.
I checked RA, and the only thing worth some money there IMO are Advics high carbon, and since Advics is a Toyota supplier, my opinion of them is somewhere in the sewage category. Bosch or Brembo? Maybe, just maybe.
I would look at EBC.
I’d had luck with the Advics rotors on a Sienna - but the brakes on those were underspeced from the factory. I’ve used Centric, DuraGo, Bendix PriorityOne, DFC and white box Chinesium over the last 10 years of brake jobs I did. I usually go for a coated or “high-carbon” rotor.
