I'm not saying that I wouldn't run without an oil filter. I'm not going to worry about the non trivial bypass PSI. Even in bypass, an oil filter is filtering.
Wasn't there a thread with a UOA withOUT a filter with good wear PPMs? or what about the useless appendage theory? Use the search feature.
My engine needs oil flow and pressure. I'd rather have the OIL FLOW and PRESSURE to reduce or eliminate any potential wear. I DON'T want my oil to be RESTRICTED by a poorly flowing filter with an overly high BPV.
Prove THIS yourself. Run your engine with NO filter. See if it fails. Then, run it with NO oil. How long will it last?
lower bypass PSI=less oil restriction=more lubrication(flow&PSI)=less wear=less need for filtration
My car has an 80PSI oil pump(volume unknown).
80psi regulator less 10psi filter restriction = 70PSI for the engine and is close to what I've measured
80psi less 30psi from a fancy German oil filter = 50psi in the engine
Which filter do you want in your engine?
With a high BPV oil filter, I'd need a higher volume oil pump with a higher PSI regulator to match the performance of the stock pump/regulator with a filter with a lower BPV. Not worth the investment for a so-called improvement in filtration that won't be seen.
And for those that believe in the thicker is better theory:
Oil flow also is needed for cooling.
Less oil flow=less cooling=hotter temps at contact points=hotter oil=thinner oil=thinner oil film=more wear
And, the oil pump PSI regulator dumps oil earlier when having more restriction downstream. So, not only is there a risk for less PSI in the motor, but flow is reduced since the oil pump regulator is dumping earlier reducing oil flow.
If you have room for the L40316, consider using the L40017.
