What do you think of the Castrol RS as an additive in Edge and maybe for the SLX OE?
http://www.castrol.com/castrol/sectiongenericarticle.do?categoryId=9021705&contentId=7040548
Castrol Power RS V–Twin — Get the Best Performance from Your Bike
Castrol Power RS V–Twin 4T is an advanced premium quality synthetic blend 4–stroke engine oil designed for modern V–Twin engines. Its power protection formula is specially designed to protect your V–twin's engine from the build up of (heat derived) power robbing deposits, enabling you to get the best performance from your bike.
Features:
* Synthetic blend 4–stroke motorcycle engine oil
* SAE 20W–40, 20W–50
* Developed specifically for V–Twin engines
* API Service SJ, JASO MA2
Benefits:
* Extreme protection at high temperatures
* Superior high speed engine protection to help extend engine life
* Protection against thermal and mechanical breakdown
* Excellent oil consumption control
* Protection against harmful engine deposits
* Excellent gear shift quality
* Excellent wet clutch performance
* Excellent protection of exhaust and catalyst system
Application:
* Castrol Power RS V–Twin is suitable for all makes of Japanese and North American 4–stroke motorcycles with integral or separate transmissions running on leaded or unleaded gasoline.
http://www.castrol.com/liveassets/bp_internet/castrol/castrol_usa/STAGING/local_assets/downloads/p,q/PowerRSVTwin4T.pdf
Test Method Typical Results
20W-50
API Service
SJ Service MA2
Specific Gravity, 60° F ASTM D1298 0.87
Pounds per Gallon 7.3
Viscosity, cSt 100°C ASTM D445 17.5
Low Temperature (°C) Cranking Viscosity, cP
max
ASTM D5293 9,500 @
-15
Low Temperature (°C) Pumping Viscosity, cP
max
ASTM D4684 60,000 @
-20
High Temperature High Shear Rate Viscosity,
cP min @ 150°C
ASTM D4683 3.7
Calcium % wt. ASTM D4951 0.075
Zinc % wt. ASTM D4951 0.127
Phosphorus % wt. ASTM D4951 0.115
If my Edge winter UOA looks bad, I have 2 fills of old green German Syntec 0w-30 I will use next winters instead. If it's a good UOA, I'll use the GC next year during warm seasons. For winters, I have a few more fills of Edge for it.
