I've got an even more obscure VW spec:
G 052 527 A2
I'm hoping to verify my transmission code to see if that helps at all. I have a 5MT and have no idea if its new or an old unit still in use.
I've seen anywhere from a 6.4 to 9.4 100*C fluid recommended for this spec.
Currently I've narrowed it down to either the Pentosin MTF2 or the ROWE HIGHTEC TOPGEAR FE SAE 75W-80 S
http://pentosin.net/specsheets/Pentosin_MTF-2.pdf
http://rowe-mineraloel.com/io/downloads/...028-11-2012.pdf
They are both 7.7 @ 100*C, which I like as a middle ground in between the 6.X and 9.X fluids. MTF2 has VI 177, ROWE calculates to 165 (not much info, no PP listed).
The ROWE data sheet states PAO and ester base, which is nice. The MTF2's specs hint at a quality base also.
The one that may win over? - ROWE specifically lists for use in G052 527. Under warranty this may be the decider.
I'm just looking for a good fluid for an early drain at 5k to get out break in metals. Then it will be extended intervals (VW says lifetime for these, of course).
Sites that carry the VW 052 527 OEM fluid are $85 after shipping. And I have no idea what fluid/viscosity I'm actually getting.
I can get the ROWE for $47 (germanautoparts) or the MTF2 for $38 from Amazon.
VW has to be the most confusing, convoluted spec list for ATF and MTF ever. They seem to change on a whim, sometimes backspec'ing. Most UOA on factory stuff are quite thin. I'd like to keep thin for MPG, too, as I'm not abusing this thing.
If I can find a cheap UOA kit, it seems worth taking a sample at 5k. Most used oil analysis seem to be from 6 speeds in GTIs or TDIs.
