Quattro Pete:
Honda/Toyota go about 30k between a cabin air filter swap. Alright, I'll give you the air filter, Honda/Toyota recommend 30k, but GM recommends 50k. No TDI in CA.
Quote:
The MkV Jetta is not aimed at the upscale economy segment. It isn't a Civic or Corolla. It targets the Accord segment and is sized nearly similarly. It is much bigger than the old MkIV and is likely bigger inside than your Saab. It probably outruns it, too.
I think the OP was frankly full of it. Spirited sub 100 mile runs on a tight new engine are not my idea of a reasonable economy yardstick. That some folks buy into it uncritically to draw blanket conclusions condemning a vehicle they never owned suggests something else. Then again, that the OP vehicle was driven with such vigor should give one a clue to its bent.
Jetta is considered a mid-sized car? I thought the Passat fulfilled that role. Nevertheless, please correct me if I'm wrong, but I still don't find the Jetta to have interior space comparable to an Accord/Camry. Is it larger than a Civic or Corolla, quite possibly, but I think to state that it's designed to compete with the Accord is a bit overstating things.
I still conclude that the obtained fuel economy figures are an accurate representation of the 2.5's performance in city driving. I used an example with my friend's 2.5L. It gets 19-20 mpg around town and its driven relatively gently...
Quote:
The 2.5L I5 is not an economy engine. It is extremely high maintenance and requires a lot of $$$ to operate and maintain. Cabin Air Filter swaps every 20k, Engine Air Filter every 40k, and new platinum plugs every 40k miles. Tire pressure monitors must also be replaced every six years. Six quarts of 502.00 complaint synthetic oil, along with a $15 filter element, every 10k miles.
You consider that "extremely high maintenance"?
I can only imagine what your definition of "low maintenance" is.
BTW, your parts costs are grossly overinflated.
Let’s do a quick comparison in maintenance costs, over a 150k period, between the Jetta and the Civic. I’ll even eliminate the TPMS monitor costs as they’re irrelevant to me. I cannot possibly include all maintenance items, so I’ll include the ones required by the manufacturer and other common ones which would show the cost difference between the Jetta and the Civic.
The local dealership here, quoted me $15.95 per oil filter element. This isn’t way out of line. But for comparison purposes, I’ll say that I was able to obtain the element for $12 online, if that makes you happier.
A little research reveals the following maintenance requirements for the Jetta:
Oil and Filter Change- 5k and 10k initial change, then every 10k miles thereafter
Spark Plugs- Every 40k miles
Engine Air Filter- Every 40k miles
Cabin Air Filter- Every 20k miles
Transmission- Fill-for-life, but I’ll say 50k miles for calculation purposes
Coolant- Fill-for-life, but I’ll say 50k miles for calculation purposes
Part Costs:
Oil and Filter Change- $6/qt for synthetic oil, six quarts required. $12 for filter element
Spark Plugs- $12/plug, five required.
Cabin Air Filter- $20
Engine Air Filter- $20
Transmission- $70 for transmission filter from DriveWire, $6/qt for Mobil 3309/Toyota T-IV complaint fluid. (Beats $30/L OE fluid)
Coolant- $25/gal for G12+
To add up the costs:
Oil/Filter Changes= 16 @ $51/each= $768
Cabin Air Filter replacement= 7 @ $20/each= $140
Engine Air Filter replacement= 3 @ $20/each= $60
Transmission Service= 3 @ $100/each= $285
Coolant Service= 3 @ $25/each= $75
Spark Plugs= 3@ $60/each= $180
Total: $1508
Here’s the Civic for a comparison. The Civic uses a flexible service system with the inclusion of an OLM, and the transmission fluid now has an OLM as well.
Based on my experience with what many users are experiencing with the Maintenance Minder system, I’ll estimate the following intervals:
Oil and Filter Change- Every 6000 miles
Spark Plugs- Every 100k miles
Cabin Air Filter- Every 25k miles
Engine Air Filter- Every 25k miles
Transmission- Every 50k miles for comparison. In the past, it has been about every 60-70k miles without the OLM through the Maintenance Minder system, so I’m expecting it to be similar.
Coolant- I’ll say every 50k miles for comparison purposes, but the first service is not supposed to be until 100k miles
Valve Adjustment- 100k miles
Part Costs:
Oil and Filter Change- $2.50/qt for 5w20 dino oil, four quarts required. $5 for filter.
Spark Plugs- $12/each, four required
Transmission- $5.50/qt, three quarts required
Coolant- $11/gal for Honda Type II Premix, one gallon required.
Valve Adjustment- $175 (assuming that you had this done)
Oil/Filter Changes= 25 @ $15/each= $375
Cabin Air Filter replacement= 6 @ $20/each= $120
Engine Air Filter replacement= 6 @ $20/each= $120
Transmission Service= 3 @ $18/each= $54
Coolant Service= 3 @ $11/each= $33
Spark Plugs= $48
Valve Adjustment= $175
Total: $925
$925 vs. $1508
The Honda costs about 40% less to maintain, even with my “comprehensive” service schedule.
