Volvo new design filter C&P
Astro14
$100 Site Donor
Staff member
Orlando
For the later model Volvos, which all have the same 4 cylinder engine, the oil filter has been redesigned. Same concept as before, a cartridge inside of a polymer canister, but this one has o-rings built into the filter and the filter housing has a drain plug a la Toyota.
Here is the filter:
Here is the housing, with the small drain plug seen as a silver, 6mm hex key insert.
Our new XC90 has 5,285 miles on the odometer. What is unknown is for how many of those miles the gasoline engine was in operation. It is operated primarily in BEV mode, and charged at home. My rough guess is that the gasoline engine has about 1,000 miles on it, nearly all of which were highway miles back and forth to Disney a few months back.
Volvo’s service interval is 1 year/10,000 miles. Likely this engine would have about 2,000 miles on it by the service interval, but I wanted to change the oil to ensure that the break in debris was removed.
So, first oil change: Genuine Volvo filter, 6 quarts of Mobil 1 Extended Performance 0w20. Some “sparklies” seen in the oil. Camera didn’t pick them up, but you could see the light reflecting in the oil. Minute bits of metal, I reckon. Break in remains.
I cut the filter. It is sturdy, and has a lot of pleats.
Zooming in on the filter media, most of the pleats were clean, but a few had the bits in them, so, overall, very little debris in the filter, but I did see a few tiny bits of red material, likely anaerobic sealant from manufacturing, and very few tiny metal bits.
Still, given the “sparklies”, I am glad that I changed it early.
Many years ago, I drove a 1998 Volvo S70 with the tear-resistant cast aluminum oil pan and a recessed steel drain plug. No issues since I went to a Fumoto drain valve.
  • Like
Reactions: JC1
Are there any menus / displays that tell you the "EV ratio" or similar ? Our Toyota has this and also every time you turn it off (and before a door gets opened), it displays a "Drive summary" that includes the % of EV mode. Sadly, there isn't an overall readout menu. I'll bet you it's in the system, accessible to Toyota tools.
Nothing that I have found, yet. It’s due for a road trip this weekend, and will see some gasoline usage. I’ll see if I can’t find any more details before the trip.
Astro14: When you did your oil change, did you unscrew the housing's drain plug?
I ask because I didn't. The PO applied a drop of colored 'something'.
I didn't know if it was a simple "tell-tale" (breaks away to alert someone to movement) or an actual securing agent.
If it was the latter, I didn't know what to apply after breaking it. I thought it might then loosen whilst driving.
I'm looking for a spot where I can drill a hole for a dipstick tube (ha-ha).
Looks good. Thanks for the clear beneath the engine shots and nice pictures of the components. Now I know what to expect when I eventually get one of these newer 4 cyl. Volvos.
I did unscrew the housing drain plug. It dribbled oil. Not nearly as effective as Toyota’s. The paint mark (and I think it was paint) wasn’t contiguous, so, I didn’t break anything. The car is under warranty, of course, so, I made certain that my presence will not be visible. Genuine Volvo plug, new crush washer, proper oil, everything cleaned and re-installed correctly.
Oil level is checked via the dashboard. With 6 quarts, it shows right at the top of the range.
Honestly, the gasoline engine hadn’t run in at least a month. My wife drives her new car primarily on the battery. That is the car’s default mode on startup.
So, in order to have a warm engine on which to change the oil, I had to go into the drive modes and select a mode that ran the engine while I drove down to the shop.
Enough to make unscrewing the housing a clean operation?
Mine too. Does the level ever go all the way to the right in yours?
There's always ~1/7th of the 'gauge's' length which doesn't fill.
We don't see Made in Tunisia very often.
Thought the same thing.
When removing the housing drain plug, the oil dribbles out slowly. It was windy, and I was holding the oil pan up close to the housing to keep the dribble from blowing all over…and I gave up after about 30 seconds, but 30 seconds was not enough to make removing the housing a clean operation.
By way of contrast, draining the Toyota housing for 15 seconds is effective.
The current oil level shows right at the top.
The new filter was also made in Tunisia.
