VOA Valvoline Transfer Case Fluid
MolaKule
Staff member
Iowegia - USA
Originally Posted by GSCJR
Dual Pump Fluid II. I don't think so.
Is this differential of a Hypoid differential design or is it integrated into a (the) transaxle ? If the differential is integrated into the transaxle, then it most likely uses Spider Gears. It looks like Honda Honda Part No.: 08200-9007. No specs or properties were given. Addendum: Did some research. This fluid is a Low Viscosity (LV) fluid about 6.0 [email protected] and > 21 [email protected], which is about the same viscosity as LV ATF's.
Ontario, Canada
It's not integrated into the transaxle; It's located at the rear of the vehicle. As I mentioned earlier I don't think it has hypoid gears. My searches for the internal components comes up empty. Thanks for looking into it; Looks like Maxlife meets the viscosity requirements, sort of.
MolaKule
Staff member
Iowegia - USA
Interesting. If you ever find any exploded views of this system I for one would be interested in seeing it. Thanks. smile
MolaKule
Staff member
Iowegia - USA
Thanks for the interesting info.
Quote
...An internal gear pump circulates VTM-4 fluid to cool and lubricate the clutches, bearings, and gears within the rear drive unit...
I suspect that since this magnetic clutch "torque distribution" differential still has a Hypoid design the Hypoid lubricant would have to have a GL-5 rating and be at least around a SAE 75W85 grade of viscosity. I also suspect the magnetic clutches are a sealed unit with a special fluid containing magnetic particles for variable torque application. And the more compact the design the more the heat rejection capability has to be built in. I don't see a gear pump illustrated nor any cooling radiator. I don't think this is the same unit as in the OP's application since his fluid is a Low Viscosity (LV) fluid about 6.0 [email protected] and > 21 [email protected]
Arizona
I agree that it's probably not quite the same. The VTM-4 Fluid is pretty low viscosity, but I don't recall that I've run any tests on it. It also calls for a change of this fluid surprisingly frequently; an initial 7500 mile changes, then every 15k miles for low speed or mountain driving, or every ~~30k otherwise.
