Virgin Wix WL10255 C&P
jlmilli
$50 site donor 2026
Missouri
Bought on RA. $7.60+shipping Wix says 21 nominal and the 2/20=6/20 beta ratio numbers which I have yet to understand but will do some reading to try and catch up. 22 psi bypass. Made in Mexico.
I believe that rating would equate to 50% (beta ratio 2) at 6 micron and 95% (beta ratio 20) at 20 micron. Decent ratings, but questionable if a tear would develop or not at that wide seam due to uneven pleats out of the box so to speak.
Wow a wix with open louvers. This one doesn't look that bad to me. Sadly, every 57002 I have grabbed off the shelf the past 2 or 3 years has had closed or louvers with holes the size of needle tips so I have moved to the MSL57002. Oddly my oil seems to stay a prettier color through the life of an oil change than it does with a poorly open wix.
Thank You for all your hard work. I appreciate it a lot
