Virgin Subaru 0w20 SM by Idemitsu
Chicago
This is virgin analysis of Subaru 0w20 SM oil by Idemitsu. Since 2012 Forester owner manual says "Always use Subaru approved oil" I was wondering what the numbers look like. Looks like it is very similar to Mazda 0w20 (also by Idemitsu) which my Subaru dealer says is approved by Subaru. One exception is Molybdenum which is much higher in Mazda version. The final goal is to determine whether Subaru oil is worth extra money (about $13 per oil change compared to 0w20 Mobil 1 in Walmart) and a trip to a dealer.
Code:
ALUMINUM 0
CHROMIUM 0
IRON 0
COPPER 0
LEAD 0
TIN 0
MOLYBDENUM 77
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 0
BORON 218
SILICON 4
SODIUM 0
CALCIUM 2071
MAGNESIUM 12
PHOSPHORUS 696
ZINC 850
BARIUM 0
INSOLUBLES 0
WATER 0
FLASHPOINT ºF 435
SUS VIS 210ºF 52.8
cSt @ 100ºF 8.13
TBN 8.6
its more like 20$ more around here
and thats without shopping for a deal.
5qt jug of Mobil 1 0w20 + 1qt = ~~29
6qt of subaru 0w20 = 6x8= 48
"Always use Subaru approved oil" Ok. What other oils meet Subaru's specs. Seems simple enough. My Corvette G.M. says Mobil 1 oil or one meeting G.M. specs. I use Amsoil XL 5w30. It meets and exceeds those G.M.specs.
Manual doesn't say "or one meeting Subaru specs". It says "if Subaru approved oil is not available then the following can be used:" and then it simply lists specs for 0w20 GF-4/GF5 SM/SN synthetic energy conserving oils. I'm sure I can get away using any 0w20 synthetic oil, it could be more trouble if warranty is denied based on "wrong" oil used. I can see lawer saying "Why were you not using Subaru (approved) oil while it was available ?"
Another question was whether Subaru oil is better than other brands. I guess I'll know more when UOA is done.
If its SM/SN 0w20 there is no issue then. Subaru knows that they can't strong arm customers into using their products specifically. Subaru oil comes from someone and of course not Subaru. Who?
Subaru oil is manufactured by Idemitsu. So I don't think you can buy it cheaply in Walmart, etc. Besides, it looks like Idemitsu oil is not the same depending on which car it is made for. Compare VOA of Mazda Idemitsu to Subaru Idemitsu, moly is different. Mazda oil is SN, Subaru I got was SM, it could be the reason, I don't know.
_________________________
2011 Subaru Forester X Prem. 5MT
Rand,
What are you using for your XT ? I heard Mobil 1 5w30 shears quickly in turbo engines, is it true ?
Rand,
This comes from a few used oil analysis on the GF4/SM Mobil 1, although there have been a few used oil analysis posted here where the SN version on the regular Mobil 1 5w30 and the EP did well and stayed in grade.
That said, many 2012 owner's still run more robust oils despite the recommendations in the manual. The manual also says that 5W-40 conventional can be used for replenishment and there is no such oil (conventionally speaking). Some Outback manuals recommend that owner's should stick with synthetic if they switch to it (SO 1980's).
-Dennis
P.S. - You may never find the answer to your question to whether ANY oil is worth it over another. Especially with a $30 used oil analysis.
http://www.bobistheoilguy.com/used-oil-analysis/
I do love moly though and there is an improvment in starting and engine/turbo reponse as confirmed by my butt dyno.
P.P.S. - There have been a few used oil analysis on the SM Subaru oils where moly was low. Maybe they changed the formula before moving to SN.
After using Mobil 1, Pennzoil Platinum and Subaru ow20 I have Quaker State Ultimate Durability in the '11 forester now and its appear to run the bestest of the bunch
Plus it was under 21 bucks for a 5qt jug - Christmas at Christmas! I bought 'em all (2!)
Just out of curiosity, what was your method to determine it was the bestest ? I can think of the following:
1. Best used oil analysis (low iron, didn't shear much or not at all, enough TBN left)
2. Best MPG
3. Lowest noise
4. Car is peppier
5. The cheapest available
I'm not sure what of the above would be the most important to me, ideally all
the VOA highly resembles the components of Quaker State Ultimate Durability--how about that one?
I guess I should give it a try. I don't think it is available in my Walmart though. Sometimes deals in auto parts stores beat even Walmart, they usually include filter however. I decided I'd use Subaru filters at this time. Usually I'd use Purolator, classic or P1, they don't seem to have one matching Subaru specs, bypass valve setting is not the same as Tokyo Roki 15208AA160 (23 in Tokyo Roki vs 12-15 in PL14459 which some auto parts store catalogs recommend for 2012 Forester).
I was afraid it would be the case. I guess it means I'll go the expensive route: VOA of Subaru oil (done), used oil analysis of Subaru oil, used oil analysis of some other oil. If used oil analysis are not so much different then I'll probably stick to that other oil. At this time I'm looking at Mobil 1 as next candidate. The reasons are simple - it is readily available for a reasonable price and used oil analysis I did in the past for Mobil 1 5w30 was decent and a little better than Pennzoil Platinum 5w30 (lower iron, higher flash point, higher TBN). used oil analysis were done for 04 Corolla at 7k OCI. Blackstone recommended trying 9k next time for both oils but I decided to stay at 7k for piece of mind. Since then I switched to Mobil 1 Extended Performance 5w30 too for the reason it is supposed to have more PAO stock and comparison of Mobil 1 Extended Performance and Amsoil (on Amsoil site) shows Mobil 1 Extended Performance is not much behind Amsoil. I trust Amsoil although the only their product I tried was MT Synchromesh fluid for 98 Accord. Gears switch noticeably better now, I forgot when was the last time they grinded while downshifting. I also put Amsoil Severe Gear 75w90 into rear diff of 2012 Forester. Nothing changed, I guess it is good news
I was afraid it would be the case. I guess it means I'll go the expensive route: VOA of Subaru oil (done), UOA of Subaru oil, UOA of some other oil. If used oil analysis are not so much different then I'll probably stick to that other oil. At this time I'm looking at Mobil 1 as next candidate. The reasons are simple - it is readily available for a reasonable price and UOA I did in the past for Mobil 1 5w30 was decent and a little better than Pennzoil Platinum 5w30 (lower iron, higher flash point, higher TBN). used oil analysis were done for 04 Corolla at 7k OCI. Blackstone recommended trying 9k next time for both oils but I decided to stay at 7k for piece of mind. Since then I switched to Mobil 1 Extended Performance 5w30 too for the reason it is supposed to have more PAO stock and comparison of Mobil 1 Extended Performance and Amsoil (on Amsoil site) shows Mobil 1 Extended Performance is not much behind Amsoil. I trust Amsoil although the only their product I tried was MT Synchromesh fluid for 98 Accord. Gears switch noticeably better now, I forgot when was the last time they grinded while downshifting. I also put Amsoil Severe Gear 75w90 into rear diff of 2012 Forester. Nothing changed, I guess it is good news
One correction, iron was higher with Mobil 1 used oil analysis, sorry (10 with Mobil 1 vs 6 in PP). Mobil 1 Flash point was still better (385 vs 370), same with TBN (2.5 vs 1.7).
I couldn't find Quaker State Ultimate Durability 0w20 VOA here. I did find 5w20 which doesn't have boron, Subaru one does. Not that I know enough to say Subaru is better because of that but at least add pack doesn't seem to be the same
It is not just the much lower moly level that differentiates this oil from the Mazda 0W-20.
The Subie oil is a different formulation to the very recent Mazda 0W-20 and is a much heavier oil due to it's lower 169 VI vs 221 for Mazda.
It's interesting to note that Mitsubishi and Honda/Acura Canada have stuck with the older Idemitsu SM GF-4 formulation that is very high in moly (625 ppm) with a 197 VI rather than going with the low moly and lower VI GF-5 Idemitsu oil that Suburu is using.
I'm not sure Subaru Idemitsu oil I sent for analysis is GF-5. Bottle I took sample from just says API SM Energy Conserving which I thought was GF-4 but I'm not an expert on that.
You are correct, API SN + Resource Conserving = ILSAC GF-5. It's reasonably likely that the oil inside the bottle is the new GF-5 formula and the bottle is mis-labeled. Older used oil analysis/VOAs show much more moly, and as CATERHAM said, the new GF-5 PDS is consistent with your VOA results.
Take a look at the most recent used oil analysis I did on my Civic HERE. All of my bottles said SM/GF-4, yet it's clearly a different formulation than my previous used oil analysis which was also Subaru 0w20 SM. The dealer where I bought the oil had just received a new shipment of oil, a year after SM was supposed to have been phased out. I suspect I got two bottles of SM and two of SN and that's why my used oil analysis looks to be halfway between your VOA and my previous used oil analysis.
