Shel_B
Site Donor 2023
- Joined
- Aug 7, 2020
- Messages
- 5,180
A while back I took a trip along Highway 50 in Nevada and did a few 100+ mph runs. When up around 100 moh the car has a subtle but noticeable vibration which is not evident at speeds below 80 mph, where I do most of my highway driving.
The vibration is not felt in the steering wheel, nor does the car body shake. It feels more like a low-level vibration running through the car. One might have such a feeling with bad motor mounts or a slightly out-of-balance tire. My mounts are new Toyota mounts, so I'd eliminate that as a problem.
Since the car drives smoothly at lower speeds, could what I'm feeling be the result of tire needing to be balanced or perhaps a defective or slightly out-of-round tire? An inspection of the tires didn't show any obvious defects but there could be some internal damage.
Besides tire/wheel issues, what else might be causing this vibration? Axle/transaxle issues? Some other suspension problems?
Thanks.
Thanks.
