For guesstimating TBN and total ash from component analyses:
All component concentrations in ppm
TBN ~ (Ca + 1.8Mg)/300
Ash% ~ (Mo + Zn + Mg + Ca) X 3/10000
It usually works out within a factor between 0.95 to 1.05 (+/- 5%)
Obviously, if you know an oil has only Ca and Zn and you know ash% and TBN, you can solve for Zn if the specs don't show it.
Because the ash is measured by weight and Mg has a lower molecular weight than Ca, thus the shift to Mg in low ash formulation detergents.
Since ash is limited in API SM/CJ4 and ACEA E6/E9/C1-4, it makes one think hard about "wanting moly" in oils vs. losing Zn.
Does anyone know what the "ashless" detergents and antiwear ingredients are in low ash oils, specifically?
Charlie
Charlie
