Very Interesting Jiffy Lube Policy
CA
Quote:
iffy Lube® is dedicated to quality. It shows in our technician training, our state-of-the-art equipment and our pledge to our customers:
* We will inform you of services that may be necessary during your visit. You make the final decision about which service(s) to purchase.
* We will recommend our services based on manufacturers' time and mileage intervals for "severe" driving conditions. However, if you don't drive in "severe" conditions or your need more information about different driving conditions, simply let us know.
* We may recommend certain services based on other criteria if the manufacturers' recommendations do not exist for them.
* We will never base fluid service recommendations on the appearance or smell of your vehicle's fluids.
* We will never charge you for services that you have not authorized or that we did not complete properly. Please ask if you would like to see or receive your used parts; we will be happy to accommodate your request.
From: http://www.jiffylube.com/customer/jiffylubepledge.aspx
Note that they say, we will never base fluid service recommendations based on the appearance or smell of your vehicle's fluids. Is Jiffy Lube actually paying attention to info from DC, Hyundai and Honda now with regards to "color of ATF" doesn't matter?
"We will never base fluid service recommendations based on the appearance or smell of your vehicle's fluids. Even if it's been changed 5 minutes ago and we know it, we'll still tell you that you need a flush."
This policy should be in the humor section. By the way, when was the last time your head light fluid was checked.
ref
"We may recommend certain services based on other criteria if the manufacturers' recommendations do not exist for them."
I'd like to see their definition of "other criteria".
This would be extra humorous if we could find out what specific problem areas and perceived weaknesses this 'quality pledge' was supposed to address.
Originally Posted By: oilyriser
I once drove a car with headlight fluid. I had to drain it once a month.
You were scammed. Headlights get a lifetime fill at the factory.
Blinker and muffler bearing fluid are another thing.
We'll bring you a dirty air filter that might be yours and hard sell you on a $40 replacement.
In defense of these guys, if you go to walmart half the time, and JL half the time, their computer has incomplete data on you. So you may look overdue.
Then they give you the hard sell of "do you know the last time your ATF was flushed" and if you say no, they say "our computer says you need it every 30k" which is all true.
The gullible, ignorant consumer who can't keep a maintenance file is to blame for the sale of their premium services, IMO.
Then they get home to their spouse who says "it was changed last winter-- those sheisters are ripoff artists, they should have seen it was pink/clear/bright green" blah blah blah.
If they recommend synthetic oil for a chrysler 2.7 for example, that might meet "other criteria" where if a "real mechanic" recommended same, you would applaud them.
ref
You think you jest. I suppose technically, the HIDs in my car actually do have "light fluid". Whether or not you could actually check it is another matter altogether...
I drilled some drain holes in my headlights. Their now self draining....
Wait -- there's fluid for muffler bearings? No wonder mine keep wearing out early!
ref
the hid bulbs do contain a fluid.mercury.
but i would like to see you top it off!
yeah, my old 87 corolla had a water leak inside of the headlight. I had to check my headlight fluid once a week.
Don't laugh too hard about liquid-filled headlights.
I can't recall where I seen it, but liquid can conceptually be used as a replacement for electrically or mechanically operated steerable headlights.
Fill the headlamp with liquid and float a beam splitter inside. As the car turns, centrifical force moves the beam splitter to one side directing the beam left and right.
