My Ram 1500 quad cab (work truck) specs 40 psi, but I run 32 - 35 psi. Makes a noticeable difference in ride quality, and tire wear is even. For the rare long distance higher speed trip, I air them back up, and also for the rare heavy load.
My F150 is a regular cab SWB XL model. Even with the new (within the last 2 years) Monroe front struts and the Monroe rear shocks, it still beats me to death on not so good roads. On nice smooth roads it rides as smooth as silk.
If you can produce specifications of car and tires for me, I can calculate a safe pressure.
Need from car, best weighed axle( end) loads in the loading you drive with, but in lack of that empty weight, number of persons ( and weight) and load generally driven with. GAwr's and GVWR.
Maximum speed you use, and wont go over for even a minute.
From tires next:
1 maximum load or loadindex.
2 kind of tire ( standard load or XL/ reinforced/ extraload, or LT with loadrange)
3. Lessimportant speedcode.
I realise this is dangerous, but if my calc gives for instance 25 psi the 35 would certainly gives discomfort and bad gripp.
So let me calculate, to get wiser.
Strange weightdivision front/rear, but OK.
Forgot to first add 10% to the 1100kg , that is the explanation for the relatively large difference
So new calc (1210kg/ 1460kg)^1.25 x 310kPa = 245kPa rounded 2.5 bar is 36 psi.
For up to 220kmph, wich can be compared to my calc for 160kmph.
Gives 2.3 bar/ 34 psi.
And that is only 1psi/0.1bar lower then my calc.
Some people have a better sense of feel. I've heard of Nascar drivers being able to feel 1/2 psi difference in tire pressure in a race.
Yes they can, but not because of comfort like we would road tyres. Grip drops off when pressures are too high or too low during race.
Not a 1/2 or even 1 psi. But my late W126 Mercedes definitely had a different feel on the same smooth CO roads at 35-36 psi vs. 32-33. It seemed livelier, somehow.Some people have a better sense of feel. I've heard of Nascar drivers being able to feel 1/2 psi difference in tire pressure in a race.
