I'm not sure what section to post this in.
I have a 2020 Ford Ecosport with the 1.0L Ecoboost engine.
That particular engine uses a variable displacement oil pump. I was just chatting with a person who is a hot rodder and engine builder and I'm just saying about that I wanted to use a different oil filter. I have used other filters in the past.
He told me that should not use any other filter other than the OEM filter which is Motorcraft FL910s.
He said these newer engines and variable displacement oil pumps are tuned to oil pressure and flow characteristics of the OEM Motorcraft filter.
That engine also has VVT. Not sure if phaser style or not. He also said the oil pressure needs to be correct, need the correct filter, for the oil pressure to adjust the camshaft for VVT.
He also said that's why it's also so critical that engine has the correct viscosity of oil. The engine doesn't so much care what viscosity of oil you use but the VVT sensors do!
Any truth to any of this? Should I really just stick to OEM filter and not deviate?
