I just picked up two quarts of Valvoline SynPower Power Steering Fluid for 10 cents at Mijers ans was wondering if its any good? It says that it meets GM spec. 9985010, Chrysler spec. 5931 and Ford spec. m2c128c. Any thoughts?
Originally Posted By: Tremo
I run a 50/50 mix of that Valvoline SynPower Power Steering Fluid and their Valvoline MaxLife Power Steering Fluid in my old Camaro. Works great.
Can I use that stuff in a Subaru?
It doesn't say any were that you can't it only says that you can't use it in Honda/Acura
I've been using it in my '01 Grand Prix with good results. I also had it in my '96 Roadmaster Wagon but a couple of times the powersteering wouldn't work on cold mornings. I did an ARX clean and flushed the wagon with Red Line pwr steering fluid and it has been good since.
You got a good deal, if it meets your spec.'s you might as well give it a try. If you don't like it you won't be out much. Chances are it will work.
