I changed the PS fluid in a 2002 Ford Focus. I did the turkey baster method. Sucked it out, filled it up, started the car turned the wheels side to side then repeated until clear.
Now my wife says she hears a whizzing/buzzing when she turns the wheels while she is driving. She said it functions properly but now makes a noise?? Any ideas what it could be.
Just FYI, the car has 50K miles and the OEM PS fluid was dark brown. Ford recommends only using Mercon ATF. I changed it to Valvoline Synpower Power steering fluid. The bottle says meets Ford Spec M2C128C.
Do you need to bleed power steering systems?
Is Valvoline not compatible? its only been in for a week and she just mentioned it today, Doh!
Should I switch it back over to the Mercon ATF
Is Ford PS and brake fluid normally very dark???
