Guys I just got my oil analysis back. It says all is good.
what am I looking for in these numbers?
Thanks for the reply. I cleaned it up and answered the questions in the original post.How many miles on your Tahoe?
How much time on this sample?
Miles on oil: 3143???
Oil: Valvoline Maxlife?
Most else pretty blurry. From what I can see:
Lead: 7 ppm (should be zero)
Viscosity: 9.6??? That's fine
TBN: 2.6??? Seems low for such low mileage on the oil and such high Ca
Thank you for the reply. According to the report it says it found no coolant or water in the oil.Thanks, much better.
Potassium is high at 7 ppm. If Sodium isn't a constituent of Maxlife, then that's another red flag for coolant intrusion.
Are you losing any coolant?
To be honest I never did an oil analysis before. I figured in about another year I will do another one to see what changes.What were you expecting to glean from the uoa? Did you suspect you there may have been a problem or if the oil was holding up for the interval
Your use will give higher numbers. I did my 2006 Toyota when I suspected maybe a coolant leak but it wasn't and that engine had about 4,000 miles in a year doing local driving and the numbers were much higher than when I had about 10,000 miles of free way driving.To be honest I never did an oil analysis before. I figured in about another year I will do another one to see what changes.
Ok. I don’t use the truck much as the mileage shows. 1/2 of the 3143 miles was highway driving.Your use will give higher numbers. I did my 2006 Toyota when I suspected maybe a coolant leak but it wasn't and that engine had about 4,000 miles in a year doing local driving and the numbers were much higher than when I had about 10,000 miles of free way driving.
That is pretty steep with TBN, but I've not seen TBN to really be linear in its decline. I've seen steep declines that leveled out and wound up good even at 8k miles. So I look at TBN as either a go or no go number. I may be wrong, but that's been my experience.It's good to have analysis of fresh oil so you have something to compare to.
Without it you can't make educated decision as to what really happened to the oil.
The 72% drop in TBN is alarming in just 3,143 miles.
Here's virgin MaxLife 5W-30
KV40 68.53
KV100 11.75
TBN 9.91
TAN 2.87
Mo 188
P 1014
Zn 1175
B 69
Mg 1123
Ca 1216
Si 16
Yes, it was steep but if one doesn't have a TAN then we don't know if there was enough TBN to combat the acid.That is pretty steep with TBN, but I've not seen TBN to really be linear in its decline. I've seen steep declines that leveled out and wound up good even at 8k miles. So I look at TBN as either a go or no go number. I may be wrong, but that's been my experience.
Is this something that can be corrected with a different motor oil?Yes, it was steep but if one doesn't have a TAN then we don't know if there was enough TBN to combat the acid.
Maybe some oil with higher TBN and lower TAN. That MaxLife has pretty high TAN to begin with.Is this something that can be corrected with a different motor oil?
I compared to every VOA and UOA (I could quickly find) using it I could over the past few years, focusing mainly on the Na and K.It's good to have analysis of fresh oil so you have something to compare to.
KV40 68.53
KV100 11.75
TBN 9.91
TAN 2.87
Mo 188
P 1014
Zn 1175
B 69
Mg 1123
Ca 1216
Si 16
