What's the top of the valve train look like through the oil fill hole? If you plan on only doing 3K OCIs with Valvoline Restore and Protect, then using a higher efficiency filter like a Carquest Premium, Premium Guard or MicroGard Select which are rated for 10K miles should be fine. A lower efficiency filter will let more debris through, especially as it loads up compared to a higher efficiency filter.
Quite a bit of varnish and some carbon buildup on the baffle plate. A nice orange hew all over when looking around on the top end.
