- Joined
- Jan 17, 2023
- Messages
- 157
If I could buy redline at $6/qt, I'd be running it full time.
No, the PDS actually states it is PAO and V. The Noack even matches the PDS from the patent. Oxidation value of Premium Blue Restore is 110. While that won't give you the ester %, it does indicate it's high.The patent stated oxidation values, in a very wide range. That has NOTHING to do with percentages of group V in the make up and it wasn't part of the patent.
8-10% will be too low, but 25%?
I found opening the oil filter neck works for me about the same. It's actually part of the instructions for certain other Hyundai Kia vehicles.Pull the dipstick, wipe it clean and then wait 5-10 minutes for the dipstick tube to drain before reinserting the dipstick. Then take your measurement.
My 4Runner would splash oil into the bottom of the dipstick tube when running, and the oil would stay caught in the tube making oil readings unreliable. Once I started waiting a few minutes for it to drain out of the tube, I got reliable and repeatable readings.
It also depends on the type of V and overall aniline point if you read the patent. Amsoil, HPL likely only have 8-10% or so group V. Red Line higher but that's a guess. I had Dave G. tell me some of their grades use up to 40%, which I'm not sure I believe. However their 5w40 or 0w40 does have a virgin oxidation value of 129 so who knows.
What's your point?
Gotcha. Over the years I have noticed that engines ran on higher end oils like Amsoil, Red Line, HPL etc. keep engines super clean. You don't see that yellow/clean tint. It's always pure metal looking.I don't dispute the high ester content of premium blue restore, but don't forget this was intended to be used for one oci, then go back to the normal oil. It is essentially a 1 oci flush.
I know you realise the difference between oxidation value and actual ester content, but it's plainly obvious a lot of people don't and they read this too. Every thread about restore muddles this distinction.
Yes anniline point is important to keep the crud suspended when the engine is not in use and the oil is cold (when the actual deposits get built up).
But haven't seen actual teardowns of engines on oils with high(ish) ester content, and was asking if you had seen them. Engines that were run normally in cars.
Yes. Valvoline Restore and Protect 0w20. I’m a traveling network technician. So I’m just finishing my second oci. I prefer to run Mobil 1 ESP 0w30 in my vehicles and will after I finish4 cycles. My 3rd and 4th runs will be 5w30 Valvoline Restore and ProtectFrom Valvoline Restore and Protect?
Nice, glad it's working for you.Yes. Valvoline Restore and Protect 0w20. I’m a traveling network technician. So I’m just finishing my second oci. I prefer to run Mobil 1 ESP 0w30 in my vehicles and will after I finish4 cycles. My 3rd and 4th runs will be 5w30 Valvoline Restore and Protect
Side note. I didn’t own the car until 230k miles so no telling what the maintenance routine or oil change intervals were previously.
It was more an issue of the oil sticking between the tube wall and the flat dipstick (this wouldn't drain out unless the dipstick is pulled). It would just smear the oil reading with extra oil. I read about the issue in the Toyota 4Runner forums. The pull, wipe and wait sequence fixed my oil checking problems.I found opening the oil filter neck works for me about the same. It's actually part of the instructions for certain other Hyundai Kia vehicles.
Sounds like 1 qt between the L and F dots to me if that's what you're seeing. The owner's manual should say what it is too.And to my knowledge, the F dot and L dot is actually a Liter, but I always thought it was a quart. Which is confusing, but idk man, a quart it seems to be, when I'm at the L dot and add a quart, it brings me to the F dot.
A Toyota owners manual I have says never check after overnight, as moisture builds up in the oil and gives an inaccurate reading.I have to wait a long time when checking my Civic, I noticed that if I'm at Walmart and I check it then it's always low but it's perfectly fine at home after I've left it sitting overnight. Evidently mine takes a long time for all of it to drain back into the pan because 5-10 min certainly isn't enough.
Same with every Honda I have owned.I have to wait a long time when checking my Civic, I noticed that if I'm at Walmart and I check it then it's always low but it's perfectly fine at home after I've left it sitting overnight. Evidently mine takes a long time for all of it to drain back into the pan because 5-10 min certainly isn't enough.
First time I've heard that. Modern engines are sealed pretty good, so I see no way that moisture could get in the oil overnight and make the oil level go up. Besides, it would take a boat load of moisture in the oil to raise the oil level, like milkshake levels.A Toyota owners manual I have says never check after overnight, as moisture builds up in the oil and gives an inaccurate reading.
Thanks. I’m glad I’m not burning oil given the mileage and maintenanceNice, glad it's working for you.
Not believable that much moisture would raise the level overnight...at least, not from the standpoint of something called "physics".A Toyota owners manual I have says never check after overnight, as moisture builds up in the oil and gives an inaccurate reading.
It recommends checking when engine is hot, 10 minutes after turning engine off for more precise reading.
What's the year/milage of the vehicle?The end of my first run with Valvoline Restore and Protect 5w30 and BMOC will be done next week..
I have only used AMSOIL Signature Series and HPL Premium Plus oil so it was already pretty clean.
2015 Honda FIT ( GDI 1.5 litre engine ).What's the year/milage of the vehicle?
Follow what the owners manual states for oil checking. Most will state checking after a few minutes after shutdown on a fully warmed up engine. The manufacturer has a specific checking procedure. Coming up with your own method may not take into account all the variables the manufacturer has such as expansion or contraction of the oil when hot or cold.I have to wait a long time when checking my Civic, I noticed that if I'm at Walmart and I check it then it's always low but it's perfectly fine at home after I've left it sitting overnight. Evidently mine takes a long time for all of it to drain back into the pan because 5-10 min certainly isn't enough.
