Obvious he doesn't. Took this right from his Q&A section of the blog this AM. Had to look back in the older section, but here it is. I know he started doing this testing because of wiped cam problems. I know from his ramblings he has no time for people here on BITOG. I feel he's trying to make Lake Speed or some one look bad, along with the people here on BITOG with what he has to say. I used to believe what he had to say, after reading some of his blog its easy to see he doesn't know squat about all the things that oil needs to accomplish in an engine. There is only one oil and one viscosity now that he claims should be used in all the liquid cooled gas engines. 5w30 Viscosity and Quaker State full synthetic. Euro oils, according to him, are trash and wrong viscosity too with their 40 weights, US speed oils according to him are far superior. I think the guys is just a bit goofy after reading some of his thoughts and unwillingness to test certain oils anymore, and his bad list contains much more than just the Valvoline Restore and Protect oil. It seems he's gone off the deep end with all his hate for some oil mfgrs. and blenders now. Kinda crazy.
MishOn
October 14, 2024 at 8:52 pm
Hi RAT,
I’m not sure if you take ‘requests’ but if you do, I’d love to see you test Valvoline “Restore and Protect” 5W30. They make a specific claim for that product: that it removes 100% of deposits on the pistons and rings after 4 consecutive oil changes. People seem to be giving it good reviews – and are experiencing less oil burning after multiple intervals, probably due to cleaner rings. Can be found in many stores. Curious if it would stand up to your test. Let me know if you can, and would love to hear your thoughts on this product, if you have any.
Thanks,
Hi there,
Valvoline’s “Restore and Protect” motor oil is a snake oil, witches brew, Marketing scam intended to separate gullible people from their money.
They dumped harsh cleaning chemicals into a motor oil and FALSELY and DISHONESTLY claim it the greatest motor oil ever created, and that it should be used starting out with brand new engines. Valvoline is so disgusting and so dishonest that I have lost all respect for that brand.
That cleaning technology was developed for dirty running diesel engines, NOT for clean running gas engines.
Those harsh cleaning chemicals that clean deposits off of stuck rings, also clean motor oil off of every internal engine component. So, long term wear, damage, or destruction is only a matter of time and miles. Buyer beware!!!
That “Restore and Protect” snake oil scam, motor oil should ONLY be used in high mileage gas engines that need help with stuck rings, or else a rebuild. In that case you really have nothing to lose, since the engine is on it’s last legs anyway.
I will not be testing “Restore and Protect” motor oil. Because my Engineering Test is designed to test normal motor oil, NOT an oddball witches brew motor oil with harsh cleaning chemicals in that will cause long term wear, damage, or destruction.
Anyone with a gas engine that is in good condition, should avoid “Restore and Protect” motor oil like the plague.
And anyone dumb enough to put that garbage “Restore and Protect” motor oil in a gas engine that is in good condition, deserves what they get.
There are plenty of good motor oils readily available that should be used. And the BEST one is 5W30 Quaker State Full Synthetic motor oil.
Take care,
540 RAT
