Scott S
Thread starter
What is a Fram titanium compared to?
Didn't you just do an oil change with Mobil 1? The same time I did?
I just changed my GDI-only Lexus 2.5 V6 over to it. That engine is infamous for GDI carboning (even had a major recall/TSB for it).So per Valvoline, this oil uses a specific new additive technology. It's not done through the use of esters like their Premium Restore Cummins product. They also said that anything the oil comes in contact with it will clean. My thinking this oil could theoretically clean intake valves.
It cleans by dissolving carbon slowly is what they say.
This is an OG Fram Titanium only available at AAP. Has the wire backed pink media of the OG Fram Ultra. 99% 20 microns 20k rating.What is a Fram titanium compared to?
Oh wow okay.. I thought they totally stopped making them...This is an OG Fram Titanium only available at AAP. Has the wire backed pink media of the OG Fram Ultra. 99% 20 microns 20k rating.
Mobil 1 EP went into my daughter’s Acura RDX also with an OG Titanium.
I've noticed the same about R&P's smell. I characterize it as burnt rubber, personally. Not awful, but it's just different.Thanks for posting these photos. I recently bought some R&P to try. I'll see if I get similar results in the top end of my 2008 Mazda MX-5.
One thing I noticed about the Valvoline Restore and Protect is that it has a distinctive odor. It isn't an offensive odor, but I haven't noticed an odor when I've opened other oils I've used recently (Mobil 1, Pennzoil Platinum, Shell Gas Truck, Castrol Edge).
I just posted the C&P in the oil filter section.Oh wow okay.. I thought they totally stopped making them...
Going in or coming out?Valvoline R&P is much darker than the Valvoline EP.
Yup, as I've said before, the goal of the API approvals is not to keep your engine deposit-free, it's to keep the rate of deposit formation at an acceptable level."Traditionally the role of engine oil has been to slow down engine deposit development, but in concocting its latest engine-protecting blend, the Valvoline team stumbled upon something… surprising."
“There are some deposits that are temporary that you can wipe off with your finger, and there are others that can get very thick,” explained Dr. Michael Warholic, global technology director, Valvoline Global Operations
“We were trying to basically minimize deposits, engine wear, friction and heat, and oil formulation is a balance, so you have to pick and choose what you want it to do,” Warholic says. “What we didn’t know was before the testing that it would remove and reverse the process – that is something you can’t predict by modeling. Restore and Protect removed engine deposits. I had never seen anything like it before, and I have eight years at Valvoline and 16 years at a company that makes the additives used in oil formulation.”
https://www.enginebuildermag.com/2024/06/dealing-with-deposits-to-boost-engine-life/
Dang,I noticed the smell as well. I thought it was quite strong, definitely different.
Anecdotally, after 600 Miles of use in my 270,6XX-mile Audi A4 3.2 Avant the Valvoline Restore and Protect has taken on a distinctly red-orange tint. I am speculating based on what can be observed through the oil port baffle that the accumulated varnish is being washed away and tinting the oil.I've got it in my 09 Accord with 278,000 miles on the clock.....If it is in fact cleaning, I would think the oil on the dipstick would darken quicker than in the past..... We shall see, only about 600 miles on the oil so far
VRP is easier to type and easier on the brain.So I have an important question. What are BITOG members going to abbreviate this oil to for their sig lines?I’m thinking V-R&P
Virgin going inGoing in or coming out
It's impossible to answer that. You have to run it. It will vary by how bad it is and how long the OCI's are.Question: If an engine had significant varnish visible when removing the valve cover, how long (in terms of miles) would Valvoline Restore and Protect take to clean off all the varnish so that metal would be shiny silver color?
From all available information that we have, which oil would clean varnish faster and more completely:It's impossible to answer that. You have to run it. It will vary by how bad it is and how long the OCI's are.
