As someone responded to me more than one occasion, no oil in this universe will fix a bad engine design.
And don't forget to downshift once in a while, It helps.I’ve got 2 jugs of restore and protect left. Will do oil change soon via fluid extractor
Explain your downshift a bit more and with which transmission and how you feel that will help.And don't forget to downshift once in a while, It helps.
Yep. It's the high vacuum during engine braking that causes the rings to "flutter" for lack of a better term. This mechanical movement will help dislodge carbon from rings.Explain your downshift a bit more and with which transmission and how you feel that will help.
My automatic vehicles I can cruise at whichever speed, step on the gas all the way and it will downshift, motor will increase rpm until shift point and then upshift automatically. I can also use a lower gear and use engine braking for slowing down which should create some extra vacuum. Which would help more?
My 4 cyl, 6MT '17 Accord sees a lot of extra vacuum engine braking as I'll leave it in gear and will decelerate accordingly. It also sees the higher RPM full throttle. That's my only vehicle currently using any and has since I got it with 50k, 5 years ago. It now has 128k. Current consumption and has been is about 1/2qt every 1300 miles. PCV changed a couple times, EC30 used, 1qt of HPL PCMO with other oils in place of EC30 multiple times, BG EPR used.
Currently it's on its 2nd OCI of Valvoline Restore and Protect so we'll see if that changes anything. I think my driving style with lots of full throttle followed by engine braking just uses more. All me manual transmission vehicles have done that.
Experiencing this currently. So far, my Fit is 5k miles into continuous Valvoline Restore and Protect use (2nd interval), and the current rate of consumption is up to 1 Qt per 3k miles as opposed to the previous rate of 1 Qt per 4k miles. And it may be more than that, I’m underestimating since it’s still early on…Quit a few people using Valvoline Restore and Protect report some increased oil consumption in the beginning, then it turns around after running for more OCIs. Could be the oil control rings lose some effectiveness as they clean up, then regain performance after getting past a certain level of cleaning. Hard to say why, but that's one theory. If your engine is burning oil for some reason other than low performing piston rings, then no oil or engine cleaner is going to help.
You cannot just use the cheapest oil and expect your engine to last a long time with no issues. The price difference between Valvoline Restore and Protect and the cheapest oil is not much when you look at a 5-quart jug of oil.
If your PCV system is working well, there shouldn’t be any flutter under vacuum.Yep. It's the high vacuum during engine braking that causes the rings to "flutter" for lack of a better term. This mechanical movement will help dislodge carbon from rings.
This is the reason the WOT was invented. Even though a lot of people forget the engine braking part.
Exactly. I replaced original pcv. Did seem to help consumption for bit so I thought.If your PCV system is working well, there shouldn’t be any flutter under vacuum.
Do you have any oil leaks? You may have oil leaks which are hard to detect (engine back seal, valve seals, etc). If your engine burns oil and you lave leaks too - the oil lost is much more.Exactly. I replaced original pcv. Did seem to help consumption for bit so I thought.
After 4 oci we can say it works on rings probably yes.Valvoline Restore and Protect has worked well for many here, but if an engine is too far worn out and using oil for other reasons besides stuck piston rings then it won't help. But others have said that it took at least 4 runs to get results, so without doing that nothing solid can be concluded.
I'm not sure how you took that away from the discussion. It has fixed burning in many older cars just like yours. I don't think you can say anything until you've done 4 or more OCIs. If you don't want to give it a full try, that's fine, but you can't say it didn't work.So basically to sum up this thread restore and protect can’t and probably won’t fix other issues in an older vehicle like mine
How could I not say this after 4 oci?I'm not sure how you took that away from the discussion. It has fixed burning in many older cars just like yours. I don't think you can say anything until you've done 4 or more OCIs. If you don't want to give it a full try, that's fine, but you can't say it didn't work.
Did you run it for 4 OCIs? Apologies if I missed that.How could I not say this after 4 oci?
As we discussed you can’t fix a bad engine design either.
2 oci’s of restore and protect 5w-30 truck consumed it faster than 10w-30 and 15w-40
It didn’t help anything but was worth ****
It looks like, he didn't.Did you run it for 4 OCIs? Apologies if I missed that.
