Valvoline Restore and Protect
Yeah I don't really think it's been tested for extended drains. I guess we will see as people like @53' Stude and others test it out.
For longer drain I’d be looking at Mobil 1 Extended Performance or the M2 Euro ESP oils . All my Hyundai / Kia engines are only good for about a 4K mile / 6 month OCI any way , so the Valvoline Restore and Protect will be just fine . About the only oils I would consider running again after Valvoline Restore and Protect engine cleaning would be Mobil 1 Extended Performance 5w30 or the Mobil 1 ESP 0w30 because they ran well in my engines and I know they are good oils .
Is your on-screen oil level reading accurate? I discussed this with another member who said the gauge never reads truly full (99%) and doesn’t seem to change (at least on mine) even after 3,000 miles. I doubt I’m NOT burning oil.
Mine does not appear to be accurate. And not in a good way. The first time the message came on, I drained the oil into a measuring container and found a whole 4 quarts removed from the sump. The message said to add one quart. Obviously something was wrong because the capacity is about 6 quarts.
This vehicle came with an extended warranty and it is doing good things for me right now. I don’t have time to do the paperwork, legwork, and mechanical work to do the warranty repairs myself so I sent it to the local Volvo dealer.
I got word today that the warranty company has approved replacement of the pistons and rings in my engine as well as all associated parts used for the repair. Supposedly this all comes with a lifetime warranty from Volvo since it was done at a dealership. They’ve also provided me with a 2025 XC40 to drive while everything has been done. So far I’ve had their vehicle for three weeks! Who knows how long it’s going to take for them to do essentially an in vehicle bottom end rebuild.
I guess that means I won’t get to find out if Valvoline Restore and Protect will fix an oil burning Volvo but I’d rather have the guarantee of updated pistons and rings than the hope that some oil will fix my issue.
That said, I’ve been so impressed with Valvoline Restore and Protect in everything else that I will be running it in this vehicle for as long as it’s available. Just to keep everything clean.
Considering trying this new oil out on my "fleet" (3 family cars, 2004 Toyota Kluger, 2004 Toyota Ist, 2008 Lexus IS350), I currently run them on Penrite HPR 5 5W-40 which is excellent, and I have another 15L in stock so won't need to buy oil for another year at least... but when I did the timing belt on the Kluger's 1MZ-FE it has varnish under the valve cover, so 🤷‍♂️ and the Lexus puffed a bit of smoke on startup after sitting for a week the other day, and the Ist sounds like it's pinging a bit when it lugs up hills sometimes... I guess new shiny things always want to be tried
can't decide on 5w30 or 10W-40, but I'm leaning towards the 10W-40
Definitely the 10W-40 in those cars.
So my first OCI of 5000kms done in a period of just over 3 months in my Holden Calais L98 6.0L.
UOA before swapping to Valvoline Restore and Protect was Penrite HPR5.
Looking at the analysis all seems good until you get to TBN which is showing near end of life. Any ideas why? Is it because of all the crap the oil might of collected in its first use cycle?
Only thing I can think of is I did get the oil quite hot up to 135C with sustained higher RPM driving but that’s never effected any oil I’ve had in the past before
Cheers
View attachment 285795So my first OCI of 5000kms done in a period of just over 3 months in my Holden Calais L98 6.0L.
Cheers
thanks for this analysis, this is of interest to me as my normal oil is Penrite HPR 5.
It appears that the HPR 5 is better looking after longer but as you mentioned that might be due to the cleaning action...
did you have any oil consumption on that Holden ?
Cheers
less calcium, less magnesium, less zddp. the first 2 are directly responsible for the tbn, and zddp acts as an anti-oxidant which helps in tbn retention. no surprise the tbn is lower (and was lower to start with).
HPR5 has a really high starting TBN. But I wouldn’t stress about Valvoline Restore and Protect having a lower TBN – look how good those wear numbers are!
No oil consumption on the Holden at all before or after. Does have almost 280,000kms on the clock.
Will be dropping the Penrite Racing ten 10ths out of my Holden SS LS1 and analysing that before adding Valvoline Restore and Protect. Should be interesting.
Any idea what the starting TBN is on Valvoline Restore and Protect?
Cheers
