Valvoline Restore and Protect
Not really. They discovered this new detergent by accident. Testing showed that it took 4 OCIs minimum to complete cleaning. This is confirmed by multiple reports here.
It could take 4 or more for complete cleaning, but that may depend on the level of cleaning needed. Going in expecting it’s going to take several oil changes is the more reasonable understanding from the outset.
They actually used to say it may take up to 4 oil changes. Now they are more clear saying a minimum of 4 or more for the complete cleaning it’s capable of.
Correction: May take up to 4 OCIs.
That's not correct.
https://www.valvolineglobal.com/en/restore-protect/
"With continuous use, Valvoline Restore and Protect Motor Oil removes up to 100% of deposits and prevents future deposit formation, restoring engines to run like factory clean.
*Piston deposit removal when used as directed for four or more consecutive oil changes at standard maintenance intervals based on adapted sequence IIIH testing."
That's not correct.
I misread your post. My bad. Yes, for complete removal they state 4 or more. I’ll go back and edit.
EDIT: They changed their marketing actually. It used to say “may take up to 4 OCIs”…now it reads a minimum of 4. I knew I wasn’t gaslighting myself. 🤪
I used to think the same thing! Until another member showed me it was minimum 4.
I could have sworn it used to say "up to 4," until I was pointed to the website. Them changing it makes sense.
This is exactly like the shampoo industry. That ol' lather, rinse and repeat gag. They doubled their sales by adding that line to the bottle. Just like "ask your Doctor if new poison X is right for you".
At least it was the shampoo industry and not the company selling preparation H ! 🤔😲
Yeah, 4 or more is new from when it was first released. That’s what threw me off. I tried going to the website you linked before your response and sure enough it said 4 or more. I think that’s better. It might take longer for some vehicles.
At the same time, we’ve also seen users try it once or twice and report on the site here reduced oil consumption; down to a negligible amount, without doing the entire 4 or more.
So, it just depends on the engine in question, that was really what I was attempting to get at. ;)
Best advice for short tripper + wanting to try Valvoline Restore and Protect ? … I believe if you are a constant short tripper with the oil often not coming up to temp - that cleaning results of Valvoline Restore and Protect will perhaps be less than desirable . At least every one to two weeks take the vehicle out on a nice interstate drive of at least 30 minutes to get the oil up to operating temp so it can do more active cleaning.
I’m joining the Valvoline Restore and Protect party.
2007 RAV4 2.4L engine currently at 241,900 miles. I have the oil consumption issue. It goes through 1qt every 500 miles. At 242,000, I’ll be dumping the old oil and go with 5w30 Valvoline Restore and Protect.
I have to make a correction on my original post/announcement. The mileage should have been 141,900 and 142,000 respectively.
Today (5/14/25) @ 142,026, I dumped out the old and in with the new, Valvoline Restore and Protect 5w30 with an STP S4967. Filled 4-1/2 qts to reach the top mark.
So here’s where I am in my current journey with Valvoline Restore and Protect: I’m an idiot and bought a car with a bad piston ring design. Avoid the 2016 XC90 if you’re looking. They fixed the oil control rings in 2017. I thought I was doing okay at first but it’s actually burning 1 quart every 1000 miles. I changed to Valvoline Restore and Protect 2000 miles ago and have already killed two quarts of the stuff.
I have a small powertrain warranty that I’m going to see if they’ll pay for replacement of my pistons and rings before it runs out. I won’t be surprised if they find a way to refuse it but hopefully Valvoline Restore and Protect will help.
The odd thing I noticed is that the engine burned the first quart in almost exactly 1000 miles. The next quart was slightly quicker around 800 miles. This time around my oil level indicator seems to be dropping even quicker! I’ve read people saying it gets worse before it gets better with this oil. Hopefully that’s the case for me
If this warranty company finds a way to get out of replacing these rings.
Since I’m not doing the ring job (I don’t have time and the warranty will pay for a loaner vehicle from the dealership), I’m going to have the local Volvo dealer do the replacement for me. I’m going to ask to keep the pistons so I can inspect the ring packs. I know it will be hard to see changes since we don’t have a baseline on ring condition but maybe we will see something interesting with it.
Which viscosity Valvoline Restore and Protect are you using?
Is the deposit-cleaning effect of Valvoline Restore and Protect dependent on
a) just having Valvoline Restore and Protect in the engine (ie infrequent car use, oil not circulating most of the time, oil film just coating internal surfaces at ambient temperature when car not in use)
b) mostly city driving, not many miles rolling over on the odometer, but lots of hours are being put on the engine, low speed city driving, stop signs, stop lights, nothing over 45 mph).
c) extended hiway driving (60 - 70 mph) but in overdrive gear with engine RPM generally 2k - 2.2k ?
In other words, if I put Valvoline Restore and Protect into a car that was my DD workhorse but for the next 6 months will see very little use, will Valvoline Restore and Protect be active to some degree in doing it's cleaning thing? (and I would likely go an entire year in this car before the next oil change).
Hard to say. Many additives need some heat to activate. That's a question you'd have to ask Valvoline.
I doubt Valvoline Restore and Protect would be all that effective if it was used in scenario A here because how will it clean the carbon buildup on the rings?
I would think that you probably don’t want to be doing lots of short trips where the oil doesn’t get up to temperature for very long. But it probably doesn’t matter if you do lots of city driving or lots of highway driving. The more important thing is to just get out there and drive it.
My anecdotal experience with Valvoline Restore and Protect is very much it needs heat and oil circulation to do its thing. If you are a short trip only user, it might take 8-10 OCIs to see a full effect.
We primarily focus on Valvoline Restore and Protect’s cleaning abilities for ring packs while also taking care of sludge and hoping it removes varnish as well . *Somewhat surprising is the low wear numbers being reported in most used oil analysis of Valvoline Restore and Protect !
