I bought the Q7 second hand from the Audi dealership that had been using the dealers Castrol Euro 5-40 in it at their recommend oil changes of 10,000 miles, done on time, every time. Carfax showed this interval also. So this oil caused the low tension oil control rings to stick to stick in the piston groves in the first place. I purchased the vehicle after it had just had the oil changed and was full of oil. 400 miles latter, it was down a quart, so I did a Berrymans B12 piston soak, BG EPR flush right after the soak and put in Valvoline Restore and Protect to polish it off. Not using any oil now in 5000 mile changes of the oil.
Low tension rings and piston deposits make for carbon stuck oil control rings. Who would have thought... Keep going long enough and the carbon chunks from the chambers and on the pistons, due to all the oil getting past the rings and burning, will eventually hang the exhaust vale open and burn the valve. So I hit the problem like a shotgun and hit it with everything I could at once to save the engine and prevent the burned valve problem from happening like has happened to others with the same 3.0 Audi supercharged engine. It worked, and no more oil consumption. Some guys have just done the Valvoline Restore and Protect, but that takes a while, so I hit it hard and fast with the piston soak first knowing it would work quick.
Many (I should say the majority of the the problems come from) using the factory recommended Castrol Euro oil have had oil control ring sticking issues, some using different oil have had a bit better luck, and some worse luck with the 3.0t engine. The guys that were tuned and run them harder seemed to be able to much longer before they started using oil, but eventually all the 3.0t CREC engines will get stuck oil control rings and start gobbling oil it would seem.
